Azkal's avatar
Azkal
Newbie Upgrade for Ultra 2 from OS4 to OS6
I have searched the old threads but couldnt find the upgrade for my specific model ( Ultra 2 ).   Recently I switched ISP and I am unable to modify the ports on the provided router. This has then c...
  • StephenB's avatar
    May 23, 2019
    Azkal wrote:
    Recently I switched ISP and I am unable to modify the ports on the provided router. This has then caused me problems accessing my Ultra 2 from outside the home network.
    That's kind of an odd reason to convert the NAS.  Can you give more information on how you are accessing the NAS from outside, and what ports you need to forward?
    Azkal wrote:
    I plan on using the 3 step upgrade using a spare blank HDD
    I'd suggest this:
    1. BACKUP, BACKUP, BACKUP
    2. Upload PREPR4TOR6_0.1-x86.bin as an add-on using the ReadyNAS web gui, but do not reboot afterwards (avoids the need to do manual factory resets)
    3. Upload R4toR6_6.9.5.bin using the ReadyNAS web gui firmware update
    4. After you upload the addon/firmware and reboot, it will update the firmware and start a factory default.
    Though your method should also work, this just saves the need to do a reset from the boot menu.
    Either way, you won't be able to migrate your current array.  You'll need to back it up, reconfigure the NAS, and then restore the data from the backup.
    Azkal wrote:
    Where do I find the most updated BIOS? is this needed before the upgrade?
    You don't need to update the Bios - OS-6 will run fine without doing that.  However, if you want to update the bios, it's easier to do that before the conversion.
    Iinstalling this as an add-on will update it  http://www.readynas.com/download/addons/x86/4.2/BIOS_Update_Package_0.5-x86.bin
ProSupport for Business
