jake1000x
Jul 22, 2016Aspirant
Newly added second drive, how do i know its working
Hi, Just installed a second hard drive into my RN102. I have a 3TB WD red in bay 1 which is my main drive with all the data on. I installed a 4TB WD red in bay 2, it has done the resync process. ...
lundmilo
Jul 22, 2016Luminary
jake1000x wrote:Hi,
Just installed a second hard drive into my RN102. I have a 3TB WD red in bay 1 which is my main drive with all the data on. I installed a 4TB WD red in bay 2, it has done the resync process. Set to X-Raid, before the install the raid was JBOD but has changed to Raid 1. This is set so the 4TB mirrors the 3TB correct? (My data will be backed-up/protected)
My main question is how do i know if the 4TB drive is copying the 3TB drive, does it just start mirroring automatically? How do i see how much it has copied so far?
When the new drive is inserted the NAS will automatically start the resync process which is actually copying the data. Saince the NAS has changed status to RAID 1 the system is running with redundancy. The system can not run RAID 1 with only one disc.
