jake1000x
Jul 22, 2016Aspirant
Newly added second drive, how do i know its working
Hi, Just installed a second hard drive into my RN102. I have a 3TB WD red in bay 1 which is my main drive with all the data on. I installed a 4TB WD red in bay 2, it has done the resync process. ...
Hopchen
Jul 23, 2016Prodigy
It sounds like the sync process went just fine, given the fact that you see a RAID1 in the GUI now.
If you go the GUI --> "System" --> "Volumes" then you should be able to see a sync process here. If there is no progess bar here and all you see is two blue disks marked as RAID1, well then all is indicating that the sync well. You can even it out by looking at the logs ("System" --> "Logs").
- jake1000xJul 23, 2016Aspirant
Oh right, i didnt know the sync process was the actual copying of data disk to disk, i thought it was some sort of set up or formatting that was needed. yes the sync process happened when i installed the 4TB drive, it took around 7/8 hours and there was a progression bar in the volumes tab. I think all is good then, i just wanted a screen with how much free space was on the 4TB but i dont think i can.
If my 3TB fails, is it just a case of putting the 4TB in bay 1 and thats it, the NAS is back to normal with all my data?
Cheers for replies.
- HopchenJul 23, 2016Prodigy
So, all looks fine then :)
Firstly, the NAS will not use the remaining 1TB of the 4TB disk. Because the original disk is 3TB, the NAS will only use 3TB of the second disk (it mirrors the disks).
If a disk fails (either of the two), then there is no need to move anything around. Your NAS will continue to work just fine. You simply just replace the failed disk.
