Pixeltje
Jul 21, 2011Aspirant
NFS issue with OSX (not lion) and NV+
Hi, I'm having some difficulties setting up nfs acces to my NV+. I can start NFS and set a number of threads (what is this? value set to one..) but it doesn't show in Finder. AFP and CIFS share w...
Pixeltje
sphardy wrote:
There's nothing you have to do more - just ensure NFS is enabled
Either you're not mounting the share appropriately, or there is a permissions issue. Note that in Frontview and NFS settings for the share you only define which hosts can access a share, not what the file/folder permissions are. Don't confuse access rights with permissions. How are you mounting the share?
I've tried nfs://<IP NAS> and that worked, but did not show any files. Also tried Automount a little while ago, but didn't saw any files or folders listed then either. I'm at work right now so can't try the automount as described in the link you just gave me. However I don't think its different from what i've tried earlier. Perhaps there is indeed something wrong with setting the acces rights, but I can't check that within the next three hours.
Nevertheless; this is what i've set for the NFS acces rights:
standard: disabled
Hosts with write-acces: <IP mbp>, <IP mbp roommate>
hosts with root-acces: <IP mbp>
