SuperJT
Aug 02, 2016Aspirant
NFS Performance issues
I work for Netapp in the NFS support area. I puchased this device almost a year ago and for the most part have been happy to have it just as a storage device. Recently I tried to put a VM on the de...
Hopchen
Aug 03, 2016Prodigy
Apart from what mdgm mentioned (definitely worth a read), can you please let us know whether you have NFS async enabled or disabled?
Go to the settings page of the share --> Network Access --> NFS --> Advanced.
This can have a very significant performance impact - running with or without async.
Thanks
SuperJT
Aug 03, 2016Aspirant
Hi all,
Thanks for the response. I looked over the KB's listed.
1) I am running 6.5.0 (1 minor version below current i believe)
2) ASYNC is not enabled (I'll play with this to see if this improves performance)
3) Bit-Rot Protection is not enabled.
4) Snapshots are enabled, set for 'smart' for management and are set to daily.
edit:
Additional outputs:
mount options
jtownsen@superjt:~$ mount | grep vm 192.168.1.79:/data/vm_store on /var/lib/kimchi/nfs_mount/vm_store type nfs (rw,relatime,vers=3,rsize=524288,wsize=524288,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,mountaddr=192.168.1.79,mountvers=3,mountport=59523,mountproto=udp,local_lock=none,addr=192.168.1.79)
top.
Tasks: 212 total, 1 running, 211 sleeping, 0 stopped, 0 zombie
%Cpu(s): 0.2 us, 0.8 sy, 0.0 ni, 85.3 id, 13.7 wa, 0.0 hi, 0.1 si, 0.0 st
KiB Mem: 3931280 total, 3245088 used, 686192 free, 312 buffers
KiB Swap: 2094844 total, 0 used, 2094844 free, 1827016 cached
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
3656 root 20 0 0 0 0 D 1.7 0.0 0:23.35 nfsd
1504 root 20 0 0 0 0 S 1.3 0.0 49:32.66 md127_raid5
3655 root 20 0 0 0 0 S 0.7 0.0 0:12.35 nfsd
1443 root 0 -20 0 0 0 S 0.3 0.0 1:28.83 kworker/2:1H
2835 root 0 -20 2228m 17m 3120 S 0.3 0.5 16:10.14 vpnserver
2954 root 35 15 1830m 71m 6596 S 0.3 1.9 6:21.11 Plex Script Hos
2957 admin 20 0 2363m 137m 5188 S 0.3 3.6 14:43.74 sabnzbd
3543 admin 20 0 130m 7376 3084 S 0.3 0.2 0:02.97 apache2
14297 root 20 0 0 0 0 S 0.3 0.0 0:01.15 kworker/u8:5
14549 root 20 0 0 0 0 S 0.3 0.0 0:00.13 kworker/2:1
1 root 20 0 45720 5052 2488 S 0.0 0.1 0:06.58 systemd
- SuperJTAug 04, 2016Aspirant
I enabled async on the volume.. Huge perf increase. 95 minutes to 4 minutes. I feel like this is indicating my disks are a problem.
root@superjt:/var/lib/kimchi/nfs_mount/vm_store# time tar xf gcc-5.3.0.tar.gz real 95m11.482s user 0m9.828s sys 0m48.948s root@superjt:/var/lib/kimchi/nfs_mount/vm_store# rm -rf gcc-5.3.0/ root@superjt:/var/lib/kimchi/nfs_mount/vm_store# time tar xf gcc-5.3.0.tar.gz real 4m7.290s user 0m8.152s sys 0m30.148s root@superjt:/var/lib/kimchi/nfs_mount/vm_store#
- StephenBAug 04, 2016Guru - Experienced User
What disks are you using?
