SuperJT
Aug 02, 2016Aspirant
NFS Performance issues
I work for Netapp in the NFS support area. I puchased this device almost a year ago and for the most part have been happy to have it just as a storage device. Recently I tried to put a VM on the de...
SuperJT
Aug 04, 2016Aspirant
I have 6x 3tb WD red drives
- StephenBAug 04, 2016Guru - Experienced User
SuperJT wrote:
I have 6x 3tb WD red drivesThey seem unlikely to be the botteneck. With single redundancy they should be giving you 100 MB/sec for both reads and writes.
You could try nastester, that will take NFS out of the equation: http://www.808.dk/?code-csharp-nas-performance
Maybe download the logs and double-check the smart stats.
- mdgm-ntgrAug 08, 2016NETGEAR Employee Retired
Did StephenB's post resolve your problem. If not, could you send me your logs (see the Sending Logs link in my sig)?
