integroid
May 09, 2018Follower
NFS Share for vmware becomes inactive
Hello,
We are using a ReadyNAS 2304 in a vmware environment. The shares are setup as NFS and we are having issues where vSphere is putting the datastore as inactive. Seems like the vcenter keep...
Retired_Member
Aug 15, 2018Hi integroid, It might also be worthwhile to check how the virtual network interface card of the virtual machine hosting the vcenter is configured. A simple approach might be to temporarily remove the virtual nic from the virtual machine and then reintroduce it. Good luck with fixing and kind regards.
