Dewdman42
May 21, 2012Virtuoso
NFS Tunning? - some benchmarks
I ran some benchmarks to compare various modes of file sharing, and got some surprising results. My intution was that NFS would be the best option, but its performance was off (see below). So do...
May 22, 2012Guru - Experienced User
I am not sure that tuning NFS will help much, and suspect it is already reasonably tuned for typical loads.
Dewdman42 wrote: correct I didn't mean that. I meant the poor sequential 4k access on NFS. Any tuning suggestions?
As I mentioned, the number of drives in the array can make a huge difference here. So JBOD is probably not the best choice if your goal is to get the max read speed. What is your raid configuration, and how many drives are in the array you are testing?
