talmage's avatar
talmage
Tutor
Dec 11, 2012
NIC IP addresses for teaming on ReadyNAS Pro 4
I just received a Pro 4 as a replacement for a broken NVX. Now I want to use both NICs. I'm using static IP addresses in my network. Do I give each of the Pro 4's NICs the same IP address?
  • no.
    when you bond the nic's in frontview, it will show them as one interface which gets 1 ip.
    I assume that you understand you need a switch that supports bonded ethernet channels, ie a managed/smart switch.
  • Talmage,
    As TeknoJuky has said, the switch must support LAG, (link Aggregation ) ,
    or Etherchannel as it may be known as.
    Both devices should be set to the same
    LACP protocol. Test at an off peak time before roll out.
    Regards, Marto
ProSupport for Business
