eggamull
Nov 12, 2017Tutor
NIC speed of NV 102
OS 6.9.0, 2 HDD 4TB, RAID 1 RN10224D
NIC works only on 100 MBit how to force switching to 1Gbits/sec?
There was a contact stuck inside the RJ45 socket. Now NIC works as before...
If you are connected to a gigabit switch or router, then the next step is to try a different cable. If some of the wires in the cable aren't connected properly then autonegotiation can fail.
