dknoebel
Aug 22, 2016Aspirant
No access to admin webinterface and Management Service is Offline
We have a Ready NAS 204. We cannot access the Web Interface after a power test of our tech-department. The Raidar says: Management Service is Offline. systemctl status readynasd says: ready...
- Aug 22, 2016
It looks like a bug was hit when attempting to parse an invalid rsync config file. Can you check the contents of /etc/frontview/rsync/Shares.conf?
mdgm-ntgr
Aug 22, 2016NETGEAR Employee Retired
Which firmware are you running?
# cat /etc/os_version
So this "power test" meant turning the power off triggering an unsafe shutdown?
Can you download the logs using RAIDar 6.1 and send them in (see the Sending Logs link in my sig)?
- dknoebelAug 22, 2016Aspirant
It's ReadyNASOS!!version=6.5.1,time=1466115662,arch=arm,descr=ReadyNASOS
Yes, they were testing the emergency power generator and the power lines. So it was an unsafe shutdown.
- mdgm-ntgrAug 22, 2016NETGEAR Employee Retired
Can you compress the core dump
# lzma -9 /var/cores/core-readynasd
and send that to us as well?So it has been working fine after you updated to 6.5.1 until the power to the system was cut?
The NAS worked on Firmware 6.5.1 before the power was cut.
I sent the compressed core dump via mail.
- May 25, 2022Retired_Member
