dknoebel
Aug 22, 2016Aspirant
No access to admin webinterface and Management Service is Offline
We have a Ready NAS 204. We cannot access the Web Interface after a power test of our tech-department. The Raidar says: Management Service is Offline. systemctl status readynasd says: ready...
- Aug 22, 2016
It looks like a bug was hit when attempting to parse an invalid rsync config file. Can you check the contents of /etc/frontview/rsync/Shares.conf?
dknoebel
It's ReadyNASOS!!version=6.5.1,time=1466115662,arch=arm,descr=ReadyNASOS
Yes, they were testing the emergency power generator and the power lines. So it was an unsafe shutdown.
mdgm-ntgr
Aug 22, 2016NETGEAR Employee Retired
Can you compress the core dump
# lzma -9 /var/cores/core-readynasd
and send that to us as well?
So it has been working fine after you updated to 6.5.1 until the power to the system was cut?
- dknoebelAug 22, 2016Aspirant
The NAS worked on Firmware 6.5.1 before the power was cut.
I sent the compressed core dump via mail.
- SkywalkerAug 22, 2016NETGEAR Expert
Thanks a lot. I deleted the lines we used to copy over some data of an old nas and rebootet.
Now it works.
- May 25, 2022Retired_Member
