dknoebel
Aug 22, 2016Aspirant
No access to admin webinterface and Management Service is Offline
We have a Ready NAS 204. We cannot access the Web Interface after a power test of our tech-department. The Raidar says: Management Service is Offline. systemctl status readynasd says: ready...
- Aug 22, 2016
It looks like a bug was hit when attempting to parse an invalid rsync config file. Can you check the contents of /etc/frontview/rsync/Shares.conf?
mdgm-ntgr
Aug 22, 2016NETGEAR Employee Retired
Can you compress the core dump
# lzma -9 /var/cores/core-readynasd
and send that to us as well?
So it has been working fine after you updated to 6.5.1 until the power to the system was cut?
Skywalker
Aug 22, 2016NETGEAR Expert
- dknoebelAug 22, 2016Aspirant
Thanks a lot. I deleted the lines we used to copy over some data of an old nas and rebootet.
Now it works.
- May 25, 2022Retired_Member
