borgchick's avatar
borgchick
no automatic mount of USB 3TB external drive
Hey all,
I have a 3TB Seagate USB drive (PN: 1DXAP3-500) I want to use to backup my RN104 (on 6.2.0).
It is formatted to NTFS, and was just checked with Windows and has no problems.
When I plug it in, nothing shows up.
I ssh into the machine, fdisk sees it.
Disk /dev/sde: 3000.6 GB, 3000592977920 bytes
255 heads, 63 sectors/track, 45600 cylinders, total 732566645 sectors
Units = sectors of 1 * 4096 = 4096 bytes
Sector size (logical/physical): 4096 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk identifier: 0x6e697373
This doesn't look like a partition table
Probably you selected the wrong device.
Device Boot Start End Blocks Id System
/dev/sde1 ? 1936269394 3772285809 3049098368 7 HPFS/NTFS/exFAT
/dev/sde2 ? 1917848077 2462285169 2177748372 73 Unknown
/dev/sde3 ? 1818575915 2362751050 2176700544 2b Unknown
/dev/sde4 ? 2844524554 2844579527 219896 61 SpeedStor
Partition table entries are not in disk order
So I try to manually mount it with the options I copied from mounting a different NTFS drive that does automount:
mount -t ufsd /dev/sde /root/usbdrive -o rw,noatime,nodiratime,nls=utf8,fmask=0,dmask=0
And it works fine.
But why doesn't the system automatically mount it?
Is it because of the other partitions on the drive?
Are there any issues with using the drive in this manually operated manner? Even after the manual mount, nothing shows up on the admin page.
1 Reply
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    The other partitions are problem y why it isn't mounted automatically.
    Manual mounting would not be recommended for general use. If you run into issues with using manual mounting that it's not something we could support.
ProSupport for Business
