rc3675
Jun 05, 2012Aspirant
NO errors AND data lost when 2 files of same name backed up
I'm running a Duo v2 running 5.3.5 As I have a number of shares, but only a single backup drive, I wondered what would happen if 2 shares had the same file name. Would both files backup correctly or ...
HERBIEO
Jun 06, 2012Aspirant
hi rc3675
i use Usb drive to back up my shares all you need to do is create seperate folders on the USB drive,
and set the path to that folder. but like sphardy says you will have to create a separate backup job for each share.
allso would it not be easier if you plugged the USB drive directly into the back of your duo.
