CarlEdman
Jan 19, 2014Luminary
"No logs exist" and things get worse
I have been running a ReadyNAS Ultra 6 Plus (6x2 TByte in X-Raid 2 mode) for some years with few problems and much success. The device was always upgraded to the latest RAIDiator and has been running...
CarlEdman
Feb 02, 2014Luminary
One more bit of information: The problem was tracked down to the java app, CrashPlan. Reviewing the logs it turns out that, about a month ago, it started crashing every couple of minutes. Each of those crashes left a /tmp/jna*.tmp file behind. The reason for the crashes in turn was that CrashPlan kept running out of memory. Altering the JVM's memory ceiling from 512 MBytes to 2 GBytes, https://support.code42.com/CrashPlan/Latest/Troubleshooting/CrashPlan_Runs_Out_Of_Memory_And_Crashes#Linux_.2F_Solaris seems to have fixed the problem for now. However, given that the ReadyNAS only has one GByte of physical RAM, I hope CrashPlan doesn't mind virtual.
