Heimchen
Aug 18, 2015Aspirant
No longer able to connect netdrive
Hi, on last weekend I recognized, that my PC (Win7Pro) is no longer able to connect my netdrives to the ReadyNAS Duo shares via CIFS. It was working for years before and I didn't change anything. I ...
Heimchen
Aug 20, 2015Aspirant
Hi,
what do you mean with security mode?
For that share only CIFS is enabled, default access is deactivated and a user with write access is defined. But also when default access is set to read/write, the login is refused.
Christian
Aug 20, 2015Guru - Experienced User
Heimchen wrote:
Hi,
The Duo v1 originally supported 3 security modes - user, share, and domain. Share mode has been deprecated, but if you were using it before that happened, you still have that option to use it. See page 27ff here: http://www.readynas.com/download/documentation/UM/RAIDiator4-1_SW_en_30Nov11.pdf
