dsnpevl
Nov 24, 2014Virtuoso
No more web GUI after upgrade to 6.2.0
I have upgraded several times before without problems. But just now I upgraded from 6.1.9 to 6.2.0, but I can no longer go to the web admin page. I can still access the file system on the NAS via W...
dsnpevl
Nov 25, 2014Virtuoso
dpkg -l | grep jenkins
ii jenkins 1.534.0 all Continuous integration system written in Java
The remove is complaining about missing dependencies.
apt-get remove jenkins
Reading package lists... Done
Building dependency tree
Reading state information... Done
You might want to run 'apt-get -f install' to correct these:
The following packages have unmet dependencies:
cpp-4.7 : Depends: gcc-4.7-base (= 4.7.2-5) but it is not going to be installed
ffmpeg : Depends: libavcodec54 (>= 1.2.0) but it is not installable
Depends: libavformat54 (>= 1.2.0) but it is not installable
Depends: libavresample1 (>= 7:1.2.6) but it is not going to be installed
g++-4.7 : Depends: gcc-4.7-base (= 4.7.2-5) but it is not going to be installed
gcc-4.7 : Depends: gcc-4.7-base (= 4.7.2-5) but it is not going to be installed
lib32gcc1 : Depends: gcc-4.7-base (= 4.7.2-5) but it is not going to be installed
lib32stdc++6 : Depends: gcc-4.7-base (= 4.7.2-5) but it is not going to be installed
libavahi-client-dev : Depends: libavahi-client3 (= 0.6.31-2) but 0.6.31-4.netgear1 is to be installed
libavahi-common-dev : Depends: libavahi-common3 (= 0.6.31-2) but 0.6.31-4.netgear1 is to be installed
libc-dev-bin : Depends: libc6 (< 2.14)
libc6-dev : Depends: libc6 (= 2.13-38+deb7u6)
libc6-i386 : Depends: libc6 (= 2.13-38+deb7u6)
libdbus-1-dev : Depends: libdbus-1-3 (= 1.6.12-1) but 1.8.0-1 is to be installed
libgomp1 : Depends: gcc-4.7-base (= 4.7.2-5) but it is not going to be installed
libitm1 : Depends: gcc-4.7-base (= 4.7.2-5) but it is not going to be installed
libjpeg-turbo8-dev : Depends: libjpeg-turbo8 (= 1.2.1-netgear1) but 1.3.1-0.netgear1 is to be installed
libquadmath0 : Depends: gcc-4.7-base (= 4.7.2-5) but it is not going to be installed
libstdc++6-4.7-dev : Depends: gcc-4.7-base (= 4.7.2-5) but it is not going to be installed
perl : Depends: perl-base (= 5.14.2-21) but 5.14.2-21+deb7u2 is to be installed
tzdata-java : Depends: tzdata (= 2013c-0wheezy1) but 2014h-0wheezy1 is to be installed
zlib1g-dev : Depends: zlib1g (= 1:1.2.7.dfsg-13) but 1:1.2.8.dfsg-1 is to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
