Bails303
Oct 28, 2012Aspirant
No network link after disk 1 failure #19879784
Recently my Pioneer Pro's disk 1 failed and now, once fully booted, it does not recognize any network link from either of its ethernet ports, either when connected directly into the modem or even when...
Bails303
Dec 06, 2012Aspirant
mdgm wrote: It wouldn't be a bad opportunity to backup all your data, and do a factory default (wipes all data, settings, everything) to get a clean system. Particularly if you haven't done so in a very long time. There have been a lot of filesystem improvements since say 4.2.8 and 4.2.22 that can only be obtained via doing a factory default.
Thanks, I'll take your advice. Finding space for 6 TB of backing up is proving quite a challenge, but it sounds like a good idea.
