ludovit8
Mar 31, 2013Aspirant
No raid or raid 0
Hi, I have raid 1. How can I disable raid to make raid 0? I found topic here, that I can make disable raid by setting up raid 0. OK. But how can I set raid 0 :-)? Can I do it from admin panel or...
ludovit8
Apr 01, 2013Aspirant
OK, I have it. I made factory procedure and insert both disk at once, and choose flex 0 raid. Now it works well.
That your hint with adding second disk later... I have some trouble with that.
ok, problem solved, thx for advices.
