Runningfree
Jul 24, 2011Aspirant
No transcoding?!
Just bought the Readynas Ultra 2 Plus for streaming media to my PS3 by a good WiFi network. I chose the Ultra 2 Plus because it has a dualcore processor powerful enough for transcoding my movies so t...
TeknoJnky
Aug 02, 2011Hero
Runningfree wrote: Ive never tested 1080p material on my old PC but 720P worked fine.
there is a pretty huge difference in the amount of processesing required between 720p and 1080p...
480p = 338,000 pixels / frame
720p = 922,000 pixels / frame
1080i = 1,037,000 pixels / frame
1080p = 2,074,000 pixels / frame
over double the number of pixels just in one frame alone
Many old-style transcoders just converts the whole file and creates a new one on the fly and that takes alot of horsepower.
this is the only way transcoding happens.
A modern way of transcoding is just to swap the container on the file (example from avi to mpeg) and let the rest just slide by in the stream. The diffrence in CPU usage is huge and the technique is not hard to manage or exotic in any manner.
this is called re-muxing, and while yes it is alot different cpu usage, its not the same as transcoding, and as already mentioned, the CLIENT has to support/understand the data stream inside the container (the container is mostly irrelevant).
