Runningfree
Jul 24, 2011Aspirant
No transcoding?!
Just bought the Readynas Ultra 2 Plus for streaming media to my PS3 by a good WiFi network. I chose the Ultra 2 Plus because it has a dualcore processor powerful enough for transcoding my movies so t...
ipaul81
Sep 07, 2011Aspirant
dudeeg wrote:
ipaul81 wrote: Yeah I agree with you Johan. The PS3 has got some great potential however Sony are just doing nothing with it. Even the menu system on the PS3 is starting to look dated. How about some intergration with IMDB for example. Teh PS3 cost a fair bit of money back in the day and Sony should consider this whilst they sit on thier hands.
BTW, I am really impressd with PS3 media server. Not bad for a freeware. I can save movies with Subtitle files on my readynas and stream them to my PS3 via PS3 meadia server software. Works really well :)
From where you do you have this add-on for your ReadyNAS? I am looking for such server for exactly the same purpose (subtitle file support)
Thanks,
G.
http://www.ps3mediaserver.org/ BUt its not a readynas add on. This is installed on your PC or Mac. The files on your Readnas can be streamed to the PS3 via this media server. Thsi means you can play MKv's and subtitle suppoprt. Only downside is you need to have your PC or Mac on to do this. Not ideal
