danlih1's avatar
danlih1
No volume exists after upgrade to 6.4.2!! Need help! #26835931
Hi!
I upgraded my ReadyNas 104 (serial 3EP336EU0048A) from 6.4.1 to firmware 6.4.2 after e-mail from Netgear.
Now after reboot I get the message ”No volume exists” and of curse all shares is lost.
The log from System->Logs
Fri May 6 2016 22:40:46
System: Firmware was upgraded to 6.4.2.
Fri May 6 2016 22:40:47
System: ReadyNASOS background service started.
Fri May 6 2016 22:40:45
System: ReadyNASOS service or process (smbd) was restarted.
Fri May 6 2016 3:18:57
Backup: Successfully completed backup job dlnas:/Data_Backuped -> dlhome:/Backup/dlnas/Data_Backuped.
Thu May 5 2016 3:10:35
Wed May 4 2016 3:22:47
Tue May 3 2016 3:49:51
snapshot: Continuous protection is no longer protecting data in volume data. Continuous protection on this volume will automatically resume as scheduled when enough space is available.
snapshot: Snapshot 2016_05_02__00_00_41 was successfully deleted from share or LUN Data_nobackup due to low free space on the volume.
Tue May 3 2016 3:48:50
snapshot: Snapshot 2016_05_02__00_00_40 was successfully deleted from share or LUN Data_dl due to low free space on the volume.
What to do (not not all data is backupd ..)?
  • Your best option is to contact Netgear support (though they might charge).  Be clear that the issue was caused by a firmware upgrade.
  • StephenB's avatar
    • danlih1's avatar
      danlih1
      Hi!
      Thanks StephenB for fast answer!
      Please advise how to best contact support?
      Kind regards Danlih1
      • StephenB's avatar
        my.netgear.com is good.  So is support.netgear.com.
ProSupport for Business
