Dilemma
Jan 19, 2017Guide
"No volumes exist" after attempting to replace a drive
I've had my ReadyNAS for several months. I began with 2x3TB drives, and ended up expanding it to 4x3TB using X-RAID. The unit has worked well. I decided to expand the array by installing larger drive...
mdgm-ntgr
Jan 19, 2017NETGEAR Employee Retired
Can you send in your logs (see the Sending Logs link in my sig)?
- DilemmaJan 19, 2017Guide
Sent
- mdgm-ntgrJan 19, 2017NETGEAR Employee Retired
Thanks. This is definitely something for support. From what I can see you have not yet registered your device?
You should go to my.netgear.com and register your device. That would be the first step.- DilemmaJan 20, 2017Guide
Thank you for your assistance, I have purchased a 3 year support plan and have submitted a support request.
