Dilemma
Jan 19, 2017Guide
"No volumes exist" after attempting to replace a drive
I've had my ReadyNAS for several months. I began with 2x3TB drives, and ended up expanding it to 4x3TB using X-RAID. The unit has worked well. I decided to expand the array by installing larger drive...
Dilemma
Jan 19, 2017Guide
Sent
mdgm-ntgr
Jan 19, 2017NETGEAR Employee Retired
Thanks. This is definitely something for support. From what I can see you have not yet registered your device?
You should go to my.netgear.com and register your device. That would be the first step.
- DilemmaJan 20, 2017Guide
Thank you for your assistance, I have purchased a 3 year support plan and have submitted a support request.
- danwarren333Apr 24, 2017Aspirant
Did you get a resolution to this problem? I have exactly the same issue...
