DLinMA
Nov 09, 2020Aspirant
Not all shares being shown
We are able to map 2 drive letters from Windows 10 to the NAS (U: and W:). When I log into the NAS server as Administrator and open Shares > Shares Listing I see only share listed, not two. I have m...
DLinMA
Nov 10, 2020Aspirant
U: \\192.168.1.2\natalie
W: \\192.168.1.2\Workgroup
The folder Natalie is not in the Workgroup folders.
I have not created any more shares in fear of possibly losing an existing share and data.
Although we do have one backup (which has problems with MAC files), I want to have another backup - just in case.
Nov 10, 2020Guru - Experienced User
Is there a user account on the NAS for Natalie? If so, this is a private "home" folder, and not a share (and it isn't shown on the share list).
One thing you can do to test this theory is to run CMD on the PC and enter
net use * /delete /y net use u: \\192.168.1.2\C /user:admin nas-admin-password
using the real admin password of course. Note this will fail if you are still using the default admin password (netgear1) So you'd need to change the password first.
The first command terminates the existing SMB sessions (so it will unmap U and W). You need to run it in order to use the admin credentials in the second command. The second command maps the full C volume fo drive letter U. You should see a "Home" folder in the root of U. If the Natalie folder is a subfolder of Home, then it is a private home folder.
If this is the case (likely it is), then the next question is whether you actually want to use the home folder feature of the NAS. As you can see, there are some disadvantages - the folders aren't very visible, and they are harder to restore from backup than normal shares. Personally I turn the feature off, and just use public shares.
- DLinMANov 11, 2020Aspirant
Is this the only way to see if the Home folder is being used? How do I disable it? If I do disable it, she won't have access to that data. Would I have to copy over the 600GB of data into another share? Or, would there be a way to share that folder?
- StephenBNov 11, 2020Guru - Experienced User
Well, if you created a NAS user account called Natalie, and she is accessing the NAS with that credential, then it is a home folder.
Yes, you'd need to move it to another share.
Navigate to security->User & Group accounts in the admin web ui. Then select "preferences" from the pulldown in the upper right. You'll see an option for "private home shares for users", that you can disable (second choice on the list).
- DLinMANov 12, 2020Aspirant
Thank you. You were right. It is a Home folder. I'm going to leave it alone. It contains about a TB of data. At least I have more confidence that the device appears to be working as it should be and my concerns have been over the lack of knowledge with this device.
