joe_schmo's avatar
Mar 05, 2018
Not expanding after resync...
I had put in a new higher capacity drive... it did its thing:
Sun Mar 4 2018 10:04:42 Disk: Disk in channel 3 (eSATA Port 1) changed state from RESYNC to ONLINE.
Sun Mar 4 2018 10:04:29 Volume: Volume eda2 health changed from Degraded to Redundant.
Sun Mar 4 2018 10:04:18 Volume: Volume eda2 is resynced.
But the UI isn't showing any progress on expanding the volume like it normally does.  I looked at previous logs and it usually shows an entry of something when it's done, like 2.5 days later - I just want to make sure it's actually working.
Is there a process I can view to see if it's working or not?
  • yxue's avatar
    yxue
    NETGEAR Expert
    You can click UI>System>Volumes, to see if there is a volume syncing, or you press buttons on front panel to see the LCD, volume syncing will show on LCD
    • That's the thing, the UI isn't showing anything. I know for a balance, I can use the btrfs commands to check. But what's the command for sync?
      Or is there something else that I can do to get it to start syncing?
      • StephenB's avatar
        What was the volume config before and after?
        Did you try a reboot?
ProSupport for Business
