mibemibe
Nov 03, 2017Aspirant
Not possible to reset password on Readynas 214 (or 312)
Hi, i'm in the process of transferring two disk from RN312 and two disks from Duo to my new RN214. I did this because I thougt my RN312 was faulty, not letting me log in anymore and I have tried nume...
mibemibe
Nov 04, 2017Aspirant
Yes, the problem is that it's impossible to reset the password on the 312 where most of my data is. I have tried 10 times doing the reset. It's very strange and for me it's a serious bug that the OS reset is not working as intended. I will do some more tests with logging from phone and different browser, but basically it's not a big problem at the moment since my plan now is to move all data and do a system reset on all devices. Takes some time but thanks to OneDrive it will work. /michael
aks
Nov 04, 2017Virtuoso
Hi Michael, where/when is your password not working, where exactly are you entering it?
Can you get the web UI as I mentioned above? I have seen many issues, but I don't recall any to do with password reset!
