BrucKlin
Mar 24, 2023Aspirant
Not sure what do about my old ReadyNAS NV+ v2 to make use of it?
Hi Experienced Readynas folks, I have an old 4-bay ReadyNAS NV+ v2 that I brought out of retirement after not using for a long time. It booted up and seems to work fine for over a week now, with...
BrucKlin
These 6TB drives are Western Digital Blue drives.
WDC WD60EZRZ-00RWYB1 5588 GB
All shucked from WD My Book enclosures.
Looking them up it says they are CMR drives, not SMR.
"Recording Technology: Conventional Magnetic Recording (CMR) Technology"
I hope they work. If not I have to toss this box.
Mar 24, 2023Guru - Experienced User
The WDC blue datasheet only lists the WD60EZAZ (SMR)and WD60EZAX (CMR). But the WD60EZRZ is an old model (2015 or so), so it predates the shift to SMR desktop drives.
BrucKlin wrote:
ReadyNAS_NV+_V2
Radiator_5.3.13
Ok. Manuals are here:
- https://www.downloads.netgear.com/files/GDC/RND2110/ReadyNAS_Duov2_NV+v2_HW_en_23-Mar-12.pdf
- https://www.downloads.netgear.com/files/GDC/READYNAS%20ARM-PLATFORM%20(DUO%20V2,%20NV+%20V2)/RAIDiator%205.3%20SW%20Manual_5Sep12.pdf
The factory default procedure is in the hardware manual (look in the boot menu section). Since one drive is at least partly synced, you should probably just use the boot menu to force the clean installation.
The NAS only support SMB 1/CIFS, so you will need to enable that on Windows PCs. Microsoft has warned that at some point they'll remove SMB 1 altogether. You could still use FTP (FileZilla or WinSCP), or NFS when that happens.
You also likely have run into the SSL protocol version mismatch problem with the browsers. There is a third-party addon that can be installed to add support for TLS 1.2 You can get that here:
- BrucKlinMar 24, 2023Aspirant
>The WDC blue datasheet only lists the WD60EZAZ (SMR)and WD60EZAX (CMR).> But the WD60EZRZ is an old model (2015 or so), so it predates the shift to SMR desktop drives.
Cool, so I got lucky with the drives I guess.
BrucKlin wrote:ReadyNAS_NV+_V2
Radiator_5.3.13
As I recall, you press the on button while pressing the reset button and use the backup button to select the action you want. I guess I wanted to verify what I remembered and to make sure it would not be destructive to anything or brick the box?
There is no data on any of the disks I need - I just want to clean and reset the box.
I had some doubt as it if there needed to be at least one disk with Ready NAS software on it? Sounds like not,
I only have Macs now. When I was testing it, it seemed that both the SMB and AFS worked OK.
You mean to access data from HTTP[S]?
I don't do that or plan on doing that, so I shouldn't need the add-on, right?
I just had SMB and AFS active, and will probably turn off SMB.
Other than that, I should be set.
Any guesses as to how long it would take to install 4 new 6TB drives?
Thanks @StephenB
- StephenBMar 24, 2023Guru - Experienced User
You do need https to access the web admin interface (the dashboard), so you should install the add-on.
I'm not a Mac user, but they are going down the same path.
- AFP was deprecated in macOS 10.9 (Mavericks), though it can still be enabled.
- SMB 1 was deprecated in macOS 10.15 (Catalina). You can patch /etc/nsmb.conf to allow it to still connect, but I don't think there is a way to configure it from normal user interface.
So, I stopped the sync on my ReadyNAS, and rebooted with the reset hole pressed
until it came up in the front-panel monitor mode. Selected Factory and pressed that
reset hole again and it booted up looking for RAIDar.
Tried Factory reset, failed. Did a reinstall OS, and that worked. Went into RAIDar,
and started to configure it, but it will not configure it for me unless I register it?
I don't have any of the original paperwork anymore. I remember I had this problem
before because I bought this at Fry's Electronics before long ago, and it was a return.
I assume the person who bought it before me and returned it must have registered it
to themselves, and I was unable to to register it.
It is impossible to contact Netgear Support on this old of a product? Oh God!
Do you actually work for Netgear and have any idea what I can do?
