Jamie2
Sep 18, 2017Aspirant
NSR NAS - Adding HDD of another Capacity
Hi, I have a Negear ReadyNAS RN10400 - 4bay and wanted to know if it is possible to add HDD's of different capacity. I have 2x 5TB Western Digital (Red) - Intellipower SATA 6 Gb/s 64 MB Ca...
- Sep 19, 2017
Jamie2 wrote:
Hi Stephen,
Can I still add 2x 6TB in to the remaining bays using JBOD and create seperate volumes for each ?
Yes. Hot-insert the disks, and create the volumes on the volumes tab.
You'll then need to create shares on those volumes.
Frontview backup jobs are handy for for copying shares to the new volumes. You'll need to create a temporary share, then create a backup job. After it completes, check the new share. Then delete the original, and rename the temporary share as desired.
Ideally you'll approximately balance the free space on each volume (making sure that no volume gets too full).
Jamie2
Sep 19, 2017Aspirant
Hi Stephen,
Thank you for your reply. I am looking to add another two disks , seperate volumes.I was asking the question because someone once told me that if you have a Negear NAS you have add addional disks with the same capacity. I will purchase a new HDD 6TB and add a new volume, I will also make sure that the HDD is the same speed as the other drives.
Thank you fotr your help.
Jamie
