castlekeep
Feb 12, 2011Aspirant
NTI Shadow problems
Hi, I seem to have the same problem that many people have with the NTI Shadow software that came wth my duo 2110 I get loads of erros indicating the files are open and therefore can not be copied....
claykin
The version of NTI Shadow including on the Duo setup CD is NOT compatible with Win 7. Netgear does not offer a Win7 solution for buyers of the Duo/NV+.
My recommendation would be to purchase a copy of Syncback+ or Pro. Its far more capable than NTI Shadow could ever dream of and for a very reasonable price you get a license to install on up to 5 PC for HOME use. http://www.2brightsparks.com/help/index ... article=27
