touffster
Apr 08, 2012Aspirant
NTP Gone MAD
Hi all, I SSH'd into my NAS this morning because nothing seemed to working properly, several restarts, troubleshooting steps and the lot and everything seemed to configured fine but failing to work...
Apr 08, 2012Guru - Experienced User
Yes on my pro (just posted it on a different thread).
Though not my Duo and NV+, which used different NTP (the Pro used time-a.netgear.com, the others uses time-e.netgear.com, which apparently is ok).
