touffster
Apr 08, 2012Aspirant
NTP Gone MAD
Hi all, I SSH'd into my NAS this morning because nothing seemed to working properly, several restarts, troubleshooting steps and the lot and everything seemed to configured fine but failing to work...
drfrogsplat
Apr 09, 2012Tutor
I had the same problem. Switched over to http://www.pool.ntp.org/zone/au as others have done and all is working again.
For anyone interested in working out the time of failure, consecutive timestamps from something I was logging (with ~10-20 seconds between each line) were:
2012-04-08 13:34:10
1992-08-23 13:34:22
I think these are GMT+11 (or GMT+10 — I corrected my timezone in the RAIDiator web admin after this, so if it was somehow obeying daylight savings without my assistance it'd be +10). Though I'm not sure if the ReadyNAS uses ntpd or ntpdate, and not sure what the update frequency might have been...
Anyway, it seems to have just been a change in date, but not the time. According to Wolfram Alpha (link at bottom for the query I used) its almost exactly 1024 weeks between those timestamps... in fact, it's just 12 seconds short, which is likely the actual time between lines in the log ;)
It's a strange error... I'd have expected roll-over on 2^8 or 2^16 not 2^10... and something in seconds, days or years... not weeks. I wonder what the source of netgear's time is... and whether they're using ntpd or something custom...
Wolfram Alpha Query: http://www.wolframalpha.com/input/?i=1992-08-23+13%3A34%3A22++to+2012-04-08+13%3A34%3A10
2012-04-08 13:34:10
1992-08-23 13:34:22
