touffster
Apr 08, 2012Aspirant
NTP Gone MAD
Hi all, I SSH'd into my NAS this morning because nothing seemed to working properly, several restarts, troubleshooting steps and the lot and everything seemed to configured fine but failing to work...
drathbun
Apr 09, 2012Aspirant
Wish wrote: How did you change which time servers you were using?
I can't find ntp.conf
EDIT: don't worry I found the right file
I changed my settings via the admin front-end, under the System tab there is an option to set the date and time, and also to enter a couple of time server addresses.
