touffster
Apr 08, 2012Aspirant
NTP Gone MAD
Hi all, I SSH'd into my NAS this morning because nothing seemed to working properly, several restarts, troubleshooting steps and the lot and everything seemed to configured fine but failing to work...
DeeCee521
Apr 09, 2012Aspirant
mine was still off, as of about 5 minutes ago and I had to manually change my ultra 4+ to the pool.ntp.org set. I manually applied the time so it was close and applied that change. Then I changed it to the pool servers and applied change. When the pool was applied, it changed by 3 minutes and then received a dialog that the readynas was now in sync with the time server. Hopefully this sticks for a while.
