mrmandrill
Feb 16, 2014Aspirant
NV+ & Virgin Superhub no connection
Hi I've searched but not really found anything that answers my query. I've Inherited an NV+ which I've factory reset and had working upstairs on dhcp over a Belkin Powerline adapter. Works fine (if...
mrmandrill
Feb 17, 2014Aspirant
vandermerwe wrote: Can you see the NAS with raidar when it's connected to the superhub?
Set a static IP address on the NAS and see if you can connect to it.
Is your powerline network connected to the hub by cable?
You have tried a different port on the superhub I presume?
I've tried a static ip which again only works via the powerline adapter.
I've tried multiports and yes the powerline is wired.
