mrmandrill
Feb 16, 2014Aspirant
NV+ & Virgin Superhub no connection
Hi I've searched but not really found anything that answers my query. I've Inherited an NV+ which I've factory reset and had working upstairs on dhcp over a Belkin Powerline adapter. Works fine (if...
vandermerwe
Feb 17, 2014Master
Is there anything in the superhub log to suggest the NAS is making attempts to get an IP address, something like dhcp request?
The NAS MAC address is in your superhub MAC address filter if you have this on?
You did not say whether raidar can see the nas?
Did you reboot the superhub after connecting the NAS to it?
If raidar cannot see the NAS then there is a problem with the connection between NAS and superhub. The cables are 5e that is fine; and you have used the same cable that was used upstairs to connect the NAS?
