mrmandrill
Feb 16, 2014Aspirant
NV+ & Virgin Superhub no connection
Hi I've searched but not really found anything that answers my query. I've Inherited an NV+ which I've factory reset and had working upstairs on dhcp over a Belkin Powerline adapter. Works fine (if...
vandermerwe
Feb 17, 2014Master
I've run out of ideas. There seems to be a physical problem with the connections when you are trying to connect it up to the superhub.
The sunset settings are all the same I presume.
Do you have a switch that you could place between the NAS and superhub?.
