mrmandrill
Feb 16, 2014Aspirant
NV+ & Virgin Superhub no connection
Hi I've searched but not really found anything that answers my query. I've Inherited an NV+ which I've factory reset and had working upstairs on dhcp over a Belkin Powerline adapter. Works fine (if...
Feb 17, 2014Guru - Experienced User
If you haven't rebooted the superhub, I suggest that you do so.
Perhaps also try a different cable.
If you have a switch, I agree it would be sensible to try putting that in between the NAS and the router.
