mrmandrill
Feb 16, 2014Aspirant
NV+ & Virgin Superhub no connection
Hi I've searched but not really found anything that answers my query.
I've Inherited an NV+ which I've factory reset and had working upstairs on dhcp over a Belkin Powerline adapter. Works fine (if a little slow).
I've moved it downstairs and plugged directly into our virgin superhub in the hope of getting a better speed. However the NV+ doesn't recieve an IP, just defaults to 192.168.168.168. I've played around with a few settings but with no luck. Both devices have the latest firmware and have had factory reset. i've checked via the powerline adapter and on a shared pc ethernet connection. Both times it recieves an IP. and thoughts anyone?
Thanks
Thanks
- StephenBGuru - Experienced UserDid you try a different cable? How about a direct connect to the PC?
