GqZXiXdU
Aug 06, 2025Aspirant
nv+ 4.1.8 usb boot for a faulty drive
i have rnv-s2-0000 nv+ v1 (sparc) x-raid currently it gets stuck in the "booting..." sequence (with 4 drivers) i am trying drives one by one in slot 1, and so far only 1 hdd (previously in sl...
Aug 07, 2025Guru - Experienced User
GqZXiXdU wrote:the unit has not been used since 2011 i think.
So really old drives.
GqZXiXdU wrote:but drive 4 presented "err bad firmware" which led me to believe that its copy of readynas firmware was corrupt
The OS is stored on the disk, and the message does mean that the NAS is seeing issues with the OS partition.
But USB recovery doesn't fix that. It replaces the firmware copy in the NAS flash, and there is no evidence there is a problem with that flash. And the process does have some risk, so I don't recommend doing that.
GqZXiXdU wrote:i will test the drives individually once i get the enclosure.
could you advise on the raid recovery approach?
Recovery would require at least three readable disks. Given their age, you might want to image them using software that does a sector-by-sector copy. Then you can recover useing the images.
R-Studio is one of several RAID recovery packages that has been used by other posters with some success:
- https://www.r-studio.com/
Note I haven't needed to use RAID recovery on my own systems, so I don't have personal experience with this software.
GqZXiXdU
Aug 07, 2025Aspirant
thank you - i understand. so i could also copy the working OS partition from working disk 3 onto disk 4, right?
but i understand that the usb restore won't restore the OS partition on the individual disk
i also understand that one needs 3 disks for the recovery to work
