elinenbe
Dec 05, 2009Aspirant
NV 4x1TB -> 4x2TB nightmare! (#10777660)
Here's what I have done so far I have a readynas NV It has 4x1TB (xraid) 4.1.6 1) I bought 4 new 2TB drives 2) Replaced each drive one at a time 3) Rebuilt successfully after each drive repla...
dbott67
Dec 07, 2009Guide
What make/model 2TB drives are you using? Some drives are known to drop out of arrays (not just with ReadyNAS; it seems to be quite common).
Make sure the disks are on the HCL. At present only the Seagate is certified for the NV/NV+:
http://www.readynas.com/?page_id=82
Can you also check the disks for errors in a SATA capable PC using vendor tools: faq.php#How_can_I_verify_that_my_disk_is_bad%3F
