Sil1
May 23, 2013Aspirant
NV+ doesn't resync after replacing HD
Hello, The fourth disk in my NV+ has growing SMART errors so I wanted to replace it. After hot swapping the drive the display said drive added, drive inserted and then nothing, no resync. All t...
May 24, 2013Guru - Experienced User
Thx. The existing drives are also 1 TB?
If so, I would simply try again. If that fails, try running WDC's diagnostic (Lifeguard) on a PC.
Another option would be to clone your drive 4 to the new drive (using block-by-block copy), and insert the new drive with the NAS powered down. Though trying again is probably better.
