Sil1
May 23, 2013Aspirant
NV+ doesn't resync after replacing HD
Hello, The fourth disk in my NV+ has growing SMART errors so I wanted to replace it. After hot swapping the drive the display said drive added, drive inserted and then nothing, no resync. All t...
May 24, 2013Guru - Experienced User
Ok. I'd move on to testing it with Lifeguard to make sure it isn't DOA.
You are using XRAID?
