valfuindor
Mar 15, 2015Aspirant
NV+ frequently hangs and slow FTP transfer speed
Hi everyone! This has been ongoing for two years but, between moving three different houses and two different countries, I didn't really have the time to look into it and just endured it. Basically,...
mdgm-ntgr
Mar 22, 2015NETGEAR Employee Retired
Nhellie wrote: Saw this one on the logs:
Disk /dev/hde doesn't contain a valid partition table
Without looking at the logs that would simply indicate to me that this disk is most likely the parity disk. I assume you started out with two disks using X-RAID in which case disk 2 would be the dedicated parity disk with no partition table on it.
If you can send me the logs I can have a look at them if you like.
