drawding
Sep 07, 2014Aspirant
NV+ hanging up every 7 days
I have a strange issue that has been happening for the last three weeks. It seems that every Sunday morning my NV+ hangs up. I'm usually not able to control it via the web management or ssh. I can'...
Sep 08, 2014Guru - Experienced User
A filing OS partition creates a number of odd symptoms, including hangs - but I don't think any other poster has seen a precise rhythm.
You can't see the OS partition; your 38% number is for the data partition.
