drawding
Sep 07, 2014Aspirant
NV+ hanging up every 7 days
I have a strange issue that has been happening for the last three weeks. It seems that every Sunday morning my NV+ hangs up. I'm usually not able to control it via the web management or ssh. I can'...
Sep 15, 2014Guru - Experienced User
You'd need to replace all 4 drives with 2 TB models to get expansion on the v1 platforms. On newer platforms, you'd need to have 2 disks of the largest size in order to use all the space (with single redundancy xraid2).
I'd definitely replace a drive with 55 reallocated sectors, even if that is not the cause of the hangup.
