drawding
Sep 07, 2014Aspirant
NV+ hanging up every 7 days
I have a strange issue that has been happening for the last three weeks. It seems that every Sunday morning my NV+ hangs up. I'm usually not able to control it via the web management or ssh. I can'...
mdgm-ntgr
Oct 05, 2014NETGEAR Employee Retired
250 reallocated sectors is a lot. Did you just run a quick/short test or did you run a long/extended test? We would recommend replacing a disk when the count is much lower than that.
An OS re-install, resets some settings (e.g. admin password, some network settings), but leaves data intact.
A factory default (wipes all data, settings, everything).
