beamsteel
Apr 17, 2012Aspirant
NV+ hangs, hard shutdown. ref. no. 18488001
Hi I have a problem where the nv+ hangs and you must do a hard shutdown and reboot the system. It has happened several times in the last month. I know the nas is a very complex system and any...
ReadySECURE
Apr 17, 2012Apprentice
beamsteel, I would first take a look at the SMART data on the drives. If you have a lot of reallocated sectors, or ATA errors, this would indicate that a drive is failing. You may want to also run a memtest on the system through the boot menu to verify that you aren't experiencing a memory issue.
