beamsteel
Apr 17, 2012Aspirant
NV+ hangs, hard shutdown. ref. no. 18488001
Hi I have a problem where the nv+ hangs and you must do a hard shutdown and reboot the system. It has happened several times in the last month. I know the nas is a very complex system and any...
mdgm-ntgr
Apr 26, 2012NETGEAR Employee Retired
Are you able to power off the NAS, then remove the drives (label) order, hook the drives up to an internal SATA port in your PC and check them using SeaTools?
